WD10EZEX-60WN4A0-00050049-WCC6Y
Bình luận: 0Lượt xem: 177
31_wdlogo-jpg.10061
>Family:................................. : TresXLB2
>Techno mode key......................... : Ok
>HDD Status sector....................... : Ok
>RAM:
>System controller (SoC)................. : LSi TT67XXC0 0x(5520)
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 256
>ROM:
>Read ROM................................ : Ok
>ROM Data size........................... : 256 Kb
>Flash ROM dir reading................... : Ok
>Flash ROM dir reading (Ext)............. : Ok (Active)
>Modules directory address............... : 191 917
>SA regions address...................... : by default
>SA regions address (RAM)................ : by default
>Module 02 access........................ : Granted
>SA SPT.................................. : 1578
>SA Translator loading................... : Ok
>ROM Modules:
>ROM version............................. : 05.49H
>Module 4F F/W version................... : 00050049
>Overlay F/W version..................... : 05.50H
>Servo F/W version....................... : 00.0A
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>Relocations............................. : 0 (3 029)
>Read ROM DCM............................ : Ok
>Power up log reading.................... : Ok
>Power up load dir data.................. : Yes
>Power up load permovl................... : Yes
>Power up load CFG data.................. : Yes
> NN | Step | Time | Flags | Info | Description
! 19 | 114 | 3.54 s | 7F | 51043750 | EXEC_POWERUP_READ_LUT(FM ERR UNABLE TO LOAD Look Up Table)
! 42 | 114 | 4.04 s | 100077F | 51043750 | EXEC_POWERUP_READ_LUT(FM ERR UNABLE TO LOAD Look Up Table)
>Service area:
>SA dir reading (ID)..................... : Ok
>Dir items loaded........................ : 469
>SA Access............................... : Copy 0,Copy 1
>Configuration reading................... : Ok
>CFG tech mode lock...................... : No
>Self encryption drive................... : No
>Master Password......................... : has not been set
>User Password........................... : has not been set
>DCM in module 47........................ : ZG
>DCM in module 0A........................ : |A|AZG83YB
>DCM in module 02........................ : S|BALKPAMZHGC8R3VYKBUG
