WD5000AZLX-60K2TA0 0005005H
Bình luận: 0Lượt xem: 679
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 1
Cyl Count............................... : 256
Zone allocation table................... : Ok
SA SPT.................................. : 1578
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 191 916
SA regions address...................... : shifted
SA regions address (RAM)................ : shifted
Module 02 access........................ : Granted
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 05.5HH
ROM F/W version......................... : 0005005H
Overlay F/W version..................... : 05.5JH
Servo F/W version....................... : 00.0A
Heads configuration..................... : by map
Heads number in use..................... : 1
Switched off heads...................... : No
Heads map............................... : 0
Service area:
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
https://drive.google.com/open?id=1bFC_1oVVUoC4p9x7YT6vAIKVs4zU_iIe
