WD3200AAJS-00L7A0-000500F9-WCAV2
Bình luận: 0Lượt xem: 980
31_wdlogo-jpg.10061
>Family:................................. : Pinclite
>Techno mode key......................... : Ok
>HDD Status sector....................... : Ok
>RAM:
>System controller (SoC)................. : 88i8846A2 0x(46A2)
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 170
>ROM:
>Read ROM................................ : Ok
>ROM Data size........................... : 192 Kb
>Flash ROM dir reading................... : Ok
>SA regions address...................... : by default
>SA regions address (RAM)................ : by default
>Module 02 access........................ : Granted
>SA SPT.................................. : 1311
>SA Translator loading................... : Ok
>ROM Modules:
>ROM version............................. : 05.F9E
>Module 4F F/W version................... : 000500F9
>Overlay F/W version..................... : 05.F9E
>Servo F/W version....................... : 04.0F
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>Relocations............................. : 0 (1 451)
>Read ROM DCM............................ : Ok
>Power up log reading.................... : Ok
>Power up load dir data.................. : Yes
>Power up load permovl................... : Yes
>Power up load CFG data.................. : Yes
>Service area:
>SA dir reading (ID)..................... : Ok
>Dir items loaded........................ : 368
>SA Access............................... : Copy 0,Copy 1
>Configuration reading................... : Ok
>CFG tech mode lock...................... : No
>Self encryption drive................... : No
>Master Password......................... : has not been set
>User Password........................... : has not been set
>DCM in module 47........................ : F7
>DCM in module 0A........................ : |Z|2F73RJC
>DCM in module 02........................ : S|BZLQP2MFH7C3RRVJKTUF
